MrWizard
Oct 09, 2016Moderator
here are a few pix
besides the step drill, i used a cut off wheel on a battery powered dremel tool, some commercial grade copper crimps (Not butt splices),
heat shrink tubing, cordless drill,
video will be up, once photobucket gets done with its processing
meter displays volts and amps (all the time)
and the green window will either watts, kwh, Cos aka power factor
so you have three items on display instead of just one, like the KAW
amps*volts gives the VA, easy math
or watts divided by the Cos/PF gives you the VA
here is quick vid on youtube https://youtu.be/wu5pD5zm8RI
i apologize for the bad audio, will get a better one up tomorrow
