MEXICOWANDERER
Oct 10, 2016Explorer
https://www.surpluscenter.com/Electrical/Miscellaneous-Electrical/Enclosures-Panels/120-240-VAC-GENERATOR-PANEL-BOX-11-3306.axd
120/240 VAC GENERATOR PANEL
New, generator panel outlet enclosure box with hinged cover. Electrical components are mounted in a plastic enclosure designed for surface mounting to a panel. Four stud mount for use with 3/16" thread cutting speed nuts. One twist-lock and two duplex receptacle outlets. Two push-button reset circuit breakers. Use for generators, electrical panels, power center for a workbench, or remove the components to install in other applications.
SPECIFICATIONS
240/120 Outlet
NEMA L14-30, 30 amp twist-lock
120 Outlets
3-prong 20 amp duplex
Circuit Breaker Rating 20 amps
Panel Opening Size 8" x 5-1/8"
Mounting Studs c/c 6-1/2" x 5-21/32"
Mounting Studs 3/16" diameter
Face Size 8-1/2" x 6-1/8"
Size 4-7/8" x 8-1/2" x 6-1/8"
Shpg. 4 lbs.
SPECIFICATIONS
240/120 Outlet
120 Outlets
Shpg. 4 lbs.
