BFL13
Oct 11, 2016Explorer II
MrWizard wrote:
Quick test of both converters
124.1v. 21.70 amps. ...2692.97va. 1996.2 watts. Cos/PF 0.742
Voltage here is higher than the previous KAW measurements from the same gen. Is that from being at the generator end of the shore power cable instead of at the converter's end?
If so, then comparisons should be from the same situation when using these kinds of meters.
