azrving
Jan 02, 2016Explorer
landyacht318 wrote:
I have the IPN pro remote, but have not experienced those issues, but grounding my body before touching the controller on dry days will be more of a concern from here on out.
My only issues was the twisted pair backing out of the receptacles and it reading crazy amperages, like -285amps.
I wonder if the controller, mine is a sb2512i, would revert to 14.2 absorption voltage as is the stock setting if the IPN failed.
Proper absorption voltage and duration are critical so I'd fear for my battery if I could not dictate how high and how long a voltage is sought, then held.
Yes indeed his was blowing out several different numbers. We had rewired from his roof down with 4 g and updated his breakers. Somewhere in there while pulling wire through his cabinets we knocked one of those small wires off. It was a moment of dread. OMG what happened now!!!:)
Having RV issues? Connect with others who have been in your shoes.24,393 PostsLatest Activity: Jun 10, 2026
