time2roll
Jul 27, 2015Nomad
Breakers do not always look tripped. Firmly switch them off and firmly back on to reset.
If the reset does not hold... you either have a bad GFCI or a fairly common ground fault.
Try unplugging the fridge and check the exterior outlet for moisture.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 28, 2026
