ryanw821
Jul 27, 2015Explorer
reisler wrote:
Thank you for the quick replies. I tried to reset the GFI but the button will not stay in. I didn't think to check the microwave or the house breaker, but will try that when I get home. Thanks :)
20, 30, 50 amps,120 volt ???? Have to read up on that :?
If the GFI will not reset there is either still some kind of fault with a device plugged in somewhere on the circuit, OR the GFI outlet itself may be defective if it wont let you reset. The GFI outlet in mine is a traditional household GFI like you would get from any home improvement store, nothing RV specific about it, not too hard to change out either (should go without saying, switch off main breaker or best yet unplug the RV while you change it).
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 28, 2026
