Vulcan_Rider
Jul 27, 2015Explorer
reisler wrote:
Thank you for the quick replies. I tried to reset the GFI but the button will not stay in.
Others are making this MUCH more complicated than it IS.
Likely that all of the outlets are protected with that ONE GFI fixture. Or at least all of them near to water of any kind.
So, when the GFI outlet will not stay reset:
The GFI outlet itself is defective.
There is a fault in some "appliance" plugged into one of the outlets.
There is a ground fault in the wiring.
Start by making sure that EVERYTHING is unplugged and try the reset again. Sometimes you must push the button PAST flush for it to catch.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 28, 2026
