SDrummer's avatar
SDrummer
HELP AC Outlets blowing devices!
Hello all,
I am currently living in a River Canyon 34RLQS0 5th Wheel that is hooked up to electrical power. I am having a odd issue with the electrical in the trailer. Some of the GFI outlets are blowing electrical devices when they are plugged in. Yesterday we plugged a toaster into the kitchen and it started smoking without even turning the device on. I also plugged my laptop AC adapter into the GFI outlet in the bedroom and it worked for about 2 minutes before blowing. The AC adapter does not give out any voltage and I verified this at my work.
The trailer has has issues in the past as it has blown the bedroom TV and kitchen Microwave as well.
I have measured the voltage on the plugs and they range from 110v-117v.
Today I tested all of the outlets with a GFI tester and they all read good indicating there are no line, neutral, or ground wires crossed.
The bizzare thing is that the plugs seem like they decide which devices they want to fry. I am currently running my heater and charging my phone on the same plug that blew my laptop AC adapter yesterday.
Any help is appreciated as I worried about plugging anything into the walls fearing it will blow the device.
Thanks
  • Is this a 50 amp rig?
    Do yo have a volt meter to check the outlets with? That would be the first place to start because the only way they can damage something is to apply excessive voltage to it.
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Dec 26, 2025
