cmcdar's avatar
cmcdar
HELP Electrical problem!
Picked up new to me camper Trail Cruiser c191 (Hybrid) travel trailer.
Battery was quite low so put a charger on it, while still connected to the camper. This morning I go out to check the voltage of the battery and it is "boiling".
I had disconnected the power to the the charger so there was no charging overnight. This morning the charger was humming and the battery is 'boiling' (hot, battery acid coming out the top). I disconnected the charger and disconnected the battery from the camper. It was almost as if the power was flowing from the camper to the battery (camper plugged into shore power - regular house extension cord).
When I went inside the camper my fuse panel was humming YIKES. Needless to say, I disconnected the extension cord.
Anybody have any idea what on earth happened?
Thanks so much!
  • By chance, are the LED's on the 120v circuit, not the 12v circuit?
  • jrnymn7 wrote:
    he or she? OP's name is caryl.
    Most likely a he.
  • It was the "bad" battery. Once replaced, everything was fine.
    This is a camper, disconnecting the battery involved one pos connection and one neg connection????
    I do have a meter as I reported in previous posts that I was checking the voltage...
    OP is a woman who has decades of experience in home building, repair, remodeling and auto mechanics. Just not a lot of experience in the new 2007 (ha ha) travel trailer technology.
    I have seasonal camped for seventeen years. First camper was a 1970 BeeLine. I then bought a 1984 28' Fleetwood. But these campers were just towed twice a year.
    So, I am a newby to having a "towable" camper. Trust me, it is a whole 'nother animal.
    I'm back in the "Happy Camper" category for now. I have already upgraded the toilet, replaced a broken potable water drain valve. Next, install back-up camera and solar panels.
    I'm sure I will need to pick your brains again.
    Thanks fella's you guys came thru in a big way and in a hurry!!!!!!
  • I'm glad it was all resolved easily.
    By the way, some converters hum by nature. It doesn't necessarily mean anything is wrong—it's just the nature of the converter. Simpler ones have a big honking 120V to 12V transformer, and if something is slightly loose internally or if the stars are misaligned or whatever it hums.
    More modern ones are switching power supplies, and these don't hum as such.
Having RV issues? Connect with others who have been in your shoes.24,190 PostsLatest Activity: Jan 19, 2025
