opnspaces
Jan 22, 2024Navigator III
Another diagram. (the one on the right is for your setup. If your tongue jack has only one wire then it goes to the positive side of the battery where all the other positive wires are hooked up (Labeled: To RV Positive +) The yellow wire between the positive and negative terminals should be the only wire that is hooked up there. I believe the yellow wire in my diagram is the same as the single black in your picture. But look yours over and make sure. Or post us a picture with both batteries exposed so we can see the other side.
