BigFly10's avatar
BigFly10
Help Identifying Wires Connected to Battery
Hello Everyone,
I just took ownership of a new Jayco Whitehawk 31DSLB and was a little confused looking at all of the wires connected to the battery. I'd like to clean this wiring up plus I have plans to add a few batteries and possibly inverter/solar.
I could use a little help from the experts on this forum to understand what all these wires are for.
The orange/black wire is for the breakaway cable. The red cable goes to my electric tongue jack. There is a 30A fuse on the red cable. The white wire, obviously, is the negative.
The two green wires attach to the battery positive and both are 30A fused. They are then connected to several other black wires that disappear to the underside of my trailer.
The green wire furthest to the right in the picture "seems" to power everything in my trailer. I left the left green wire disconnected and didn't notice any loss in functionality of anything. Similarly, I connected ONLY the green wire on the left of the picture and nothing at all seemed to work.
I would appreciate any help someone can provide me.
Thanks.
Ryan
  • Those are some very small wires, especially to the + terminal.
    Jim
  • Somebody on here has a Jayco and said the green wires were positive, with one going to the power centre (DC fuse panel and converter) with a 30a fuse, so the other is likely for the slide motor.(Lippert spec has a 30a fuse on our slide motor pos wire) (you already identified the jack one)
    The 7-pin pos will merge with a pos wire somewhere on the way to the pos batt post
    Hard to clean up wiring, but some use a buss bar approach to collect a bunch of wires and then just have one wire to the battery post.
    If you get a Trimetric, you will have the shunt act as a buss bar, where one end goes to the battery neg post and the other end takes a bunch of neg wires.
    Solar and an inverter add to the fun!
  • BigFly10 wrote:
    Sorry, I think I messed up the picture. Let's try this.
    It looks to me like the right side green cable goes to an inline fuse (or is that just a connector?) then connects to the red wire and three more smaller black wires at the blue Marrette.
    One of those seems to be in with the black and white wires. Any idea where any of the three go? Can you see where the two individual black wires go? It's possible that one goes to the trailer plug as charging cable. Do you have a power leveling system?
