Lspangler's avatar
Lspangler
Help me buy an inverter
I don't think I need anything fancy. I have 2 things I want to run on battery occasionally.
1. Keurig Coffee maker 1450 watts for about 6 minutes per day
2. Fridge in my outdoor kitchen when driving.
I'm thinking a 4000 max / 2000 continuous inverter from Harbor Freight should do the trick.
Is there anyway to make an inexpensive inverter switch over to 12v automatically when 120 v is not available and back when it is?
Any help or input is most appreciated.
Also, my outdoot kitchen is in the front of my trailer. I plan to mount the inverter in there with 0 gauge cables about 6 - 8 ft long going to my 2 6v GC batteries. I will add a plug inside on the unused bunk over the fridge to plug the coffee maker in.
Thanks
Linc
  • FWIW that coffee maker is pushing the costs on the whole project,all for 6 minutes a day. Is there a suitable substitute that uses 12v or LP?
    As said, if you want to power 1500 watts, you'll need a big inverter (and not a cheap one) and more batteries. Also, 8 feet of 0 awg is too thin for 1500 watts. I use 0000awg ("four-ought") and I still see a voltage drop.
    My advice: Get a nice little inverter that will run your fridge on the road (and you'll only need 2 batts), and figure out something else for your coffee maker.
    Oops, that's a resi fridge, isn't it? Two tousan dollah!
  • I have and recommend Go Power 2000 watt sine wave. Good luck with HF.
    I agree 2 batteries is marginal at best.
    That wire is a bit long and thin for 2000 watts.
    Yes you will need a $60 transfer switch to wire this into an existing 120v circuit. 12v power is always on as supplied from the battery, no switching needed.
    ..to my 2 6v GC batteries.
    I don't understand the question. An expensive IC will detect shore power and pass that to the coach. Is that what you mean?
    You're going to find that just 2 batteries will not likely run your Keurig for the whole 6 minutes. Get 2 more.
    Harbor Freight stuff is notoriously questionable quality. Cheap out now and you may wish you'd gotten a pure sine inverter later.
    Don Rowe site Inverter FAQ
    Inverters by Phred
    inverter thread
    MSW v. pure sine
    Inverters and MW thread
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Dec 26, 2025
