DiskDoctr's avatar
DiskDoctr
Help me choose a fuse and shunt
Four 6v golf cart batteries connected together with 2AWG wire, then 4/0 wire used to connect to the inverter posts. Inverter posts also connect to PD9270 converter/charger.
According to wiring guides and help from folks here, it should be good to 400amps DC.
The inverter is the biggest load, a Xantrex ProSine 1800 that surges to 2800amps max (momentary).
I'd like a fuse setup that isn't too bulky, is easy to check, protected from shorts against the battery box lid (and rugged housing), and looks nice.
I would also like to add a shunt to keep an eye on everything battery related. It's been recommended I use a 200 amp shunt between battery negative terminal and negative lead (right?)
Currently the frame ground is too small and the original wiring uses breakers (reverse wiring protection or overload?) that are corroded and must be replaced.
I'm thinking a monster-sized frame ground lug/bar with a 2 AWG wire from the inverter's negative terminal to the new frame lug, where it joins the existing line to all the house DC via distribution panel, brakes, etc.
Here are some styles I'm looking into.
shunt
I like the clear housings that take wire into each end and crimp it, but nothing I've found supports the 4/0 cable, so I'm looking at terminal threaded posts/bolts.
Ideas? Pics? Experiences?
Thanks!
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 18, 2026
