CentralcoastCal's avatar
Mar 07, 2016
Help me hook up my battery/inverter wiring before I crack!
Hello,
Recently we,(my family and I purchased a 1o75 Dodge Sportsman Lazy Daze Class C motorbike. Its a temporary fix to a desperate need of housing situation, and I have to admit that I'm in over my head!!
I'm still figuring out the water and propane systems, which seem pretty simple, however I am stuck with the battery/power inverter assembly or diagram.. I quickly learned that trial and error is not an optimal method of knowledge or completion in Deep cycle systems with voltage ampliried through a 2000 watt inverter and 3 600ma 12v deep cycle batteries.
I have no generator or solar panels and very little,accessory-wise, works without shore power. I've read somewhere here that many set ups were not made to work without shore power but I'm in a situation where I will need that often.
We are pretty poor so with that in mind do you have any advice on an affordable boondock set up? Also a wiring dagram for a starting batt, 3 12 v 600ma deep cycle Batts. and a 2000 watt inverter. A thong CentralcoastCalifamily cantcontent://media/external/file/24965
Having RV issues? Connect with others who have been in your shoes.24,336 PostsLatest Activity: Nov 16, 2025
