ScottG
Dec 29, 2013Nomad
If all is working correctly it should not trip it. You have a condition that could be dangerous and really should be corrected.
The fridge is always the first thing to check. Try unplugging it to see if it still trips. If so then the heater in the fridge needs replacement.
If not then try unplugging every other item in the RV and see what happens.
Also check the outside receptacles for moisture which can make a GFCI trip.
Good luck,
Scott
Good luck,
Scott
Having RV issues? Connect with others who have been in your shoes.24,382 PostsLatest Activity: Apr 22, 2026
