oilslick
Jan 01, 2014Explorer
wolfe10 wrote:
But with either an ATS or manual plug, the generator wiring is NOT wired to the coach when plugged in. Both neutral and hot(s) are switched.
The Op stated that when the Transfer switch was turned off everything worked which led me to believe the generator WAS connected or partially connected but not running.
Having RV issues? Connect with others who have been in your shoes.24,382 PostsLatest Activity: Apr 22, 2026
