Mandalay_Parr
Jan 01, 2014Explorer
oilslick wrote:wolfe10 wrote:
But with either an ATS or manual plug, the generator wiring is NOT wired to the coach when plugged in. Both neutral and hot(s) are switched.
The Op stated that when the Transfer switch was turned off everything worked which led me to believe the generator WAS connected or partially connected but not running.
I believe she said the transfer switch was disconnected. In other words bypassed.
Jerry
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: May 13, 2026
