We have a 2006 coachman. I have interior and exterior lights. No fridge, fan, a/c or furnace. Checked all fuses and breakers seem to be fine. Battery was completely dead so disconnected it. The pump b...
It sounds like the converter isn't working at all. I would check the reverse polarity fuses in case you accidentally hooked up the batts backwards or a battery shorted internally. These (3 each) are separate from the other fuses on the panel.
Having RV issues? Connect with others who have been in your shoes.24,390 PostsLatest Activity: Jun 05, 2026
