RoadLife's avatar
RoadLife
Help! Rear Jacks won't retract 2003 allegro bus
2003 Allegro Bus. We are looking for the hydraulic pump manifold assembly and the valve release t handles so we can manually lift the jacks. Does anyone have a clue where these can be found? We have the HWH 610 leveling system.
  • j-d's avatar
    j-d
    Explorer II
    If I looked it up correctly, this is the 610 Service Manual
    I'm hoping you'll find the Pump and Manifold, and notice a wire(s) off or loose ground. Have you looked at the wiring at the two rear jacks?
  • Doug you are right, it is the 610. I looked at the wrong one online. (this is the wife asking....)
    That's a good suggestion We will do that. Thanks.
  • You must have a hybrid system. HWH 2000 is air leveling only. Not familiar with a Air/Hydraulic 2000 system. HWH makes a Air/Hydraulic but it is not called the 2000 system. All you have to do is activate the Hydraulic motor and walk around the outside of the RV to determine its location and then the valves/solenoids will be on that pump. Here is the service manual for the 2000 system. Doug
    http://www.hwhcorp.com/ml31043.pdf
