eZAK
Jun 10, 2013Explorer
Help with landing gear replacement!
The driver's side front landing gear will not move under load. Motor runs gears spin. Venture mfg., 2008 28E33SA Titanium by Glendale.
I would like to take the whole thing out (tube sections) But I can't figure out how to do that. I unbolted it at 2 locations but it appears to be heavily siliconed in where it meets the floor with a metal plate.
So I took off the motor, and the gear box. (gears look fine)
I then took the top cover off the tube. (again gears look fine) It is hard to tell but I believe the bottom gear maybe slipping on the shaft or the threaded shaft may have a bad spot. (stripped?)
I was able to get the top horizontal shaft and gear off,
But I can't seem to get the bottom gear off the main vertical shaft.
Don't see any pin.
Any Ideas?
Thanks
Don't see any pin.
Any Ideas?
Thanks
