BFL13
Oct 10, 2013Explorer II
AFAIK, that number (different for type of battery. 1.25 is in the middle) is to help keep the accumulated AH figure correct which is used to estimate the SOC where you pick a number for bank capacity.
IMO your bank capacity changes so much with temperature, whatever you enter for capacity will be wrong, so the est for SOC using the accumulated AHs will be wrong too just from that.
So no point is using the correct Peukert figure--the 1.25 is close enough so you won't be any worse off in the estimated SOC WAG
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 17, 2026
