johnm1's avatar
johnm1
Help with setting up and using DC120100C SOC battery monitor
Apparently I'm much more dense than I thought (my wife would agree).
I've installed the DC120100C monitor and now I need help in understanding what to do with it. My goal to to monitor the batteries while dry camping (3 day weekends to 2 week trips) so I know when, and for how long, to run the genny. I don't have solar.
- I have this meter
- I have 2 Duracell 6V RV batteries (SLIGC115) from Batteries Plus at 230AH each for a total of ... 230AH's.
- I set the AH capacity to 230.
- What do I look at, or push, to see the SOC value? And what am I looking at to read this?
- Do I need to enter/change another value?
- I see here that some are calibrating the unit? Do I need to? I only need the monitor to give me a good close estimate ... it doesn't need to be dead on (would be nice if it was though).
- Long story short, the instructions that came with it stink. How do I use it and learn from it?
If I missed some needed info, please let me know and I'll add it.
Thanks,
  • i don't think you need to calibrate the voltage, mine reads very close to my DMM
    voltage versus SOC is an indicator of battery 'condition'
    noting what is is when new, and what it is later, gives you an idea of how the battery is aging, aka holding up
    saying comparing Volts at 80% soc now
    and then again a few months from now or next spring etc..
    i watch volts when charging against how many amps the batteries are taking at 'that voltage' against the SOC ampHr count
    'trends and tendencies' as Mexi is always saying
  • That clears it up a bit - Thank you.
    - Should I be concerned about the voltage?
    - Do I need to calibrate it or is it "good enough" out of the box?
    Thanks so much for the video. Such a simple thing and it helped a bunch.
    We're not heavy users of the batteries (no 120VAC stuff running off the batt's). However, I don't like getting caught with my pants down if I run out of juice and I could have recharged during the day. I just don't like to "worry". If I worry too much, I run out of beer and, well, we don't want to go there!
  • 608 is the amphrs still in my bank (you set your banks total size, the use number is removed from the set number, the number displayed is what is left in the bank}
    the AH capacity is set at 674, 674 is full, 100% SOC
    608 is approx 90% SOC
  • the bottom button the AH button, pushing this one cycles thru the the display
    differernt little LEDs on the right hand side will be on indicating which mode is being displayed
    AMPS rate of charge or discharge ... LED 'A'
    Amp hours , shows present amphr count, goes down if discharging
    goes up, when charging, will stop counting when it hits your 230 preset... LED 'AH'
    Percent AKA SOC gives you a 3 digit number like 87.2 LED '%' will be on
    look at this video, i cycle it thru the display modes
    batteries are at 608 AH 90% SOC down 66ah from the 674ah set point
    using about 21amps discharge
    there is a CHARGE LED above the amps led, the charge LED lights when you are charging, not on and the amps reading is discharge/use
    there is NO plus or minus sign
    http://vid298.photobucket.com/albums/mm251/Mr__Wizard/20160817_234329_zpsfd3htmvx.mp4
    you can watch how much you are taking out
    or set it on percent, and when you see it get to a certain level like 75% or 50% do a recharge
    it varies depending on your style of camping
    the first day you might want to go about your normal USE routine, and then check the ah count and percent numbers before the recharge ?
    we are heavy users and recharge every day, but you may not need to
  • I guess the instructions for my Trimetric were worth a $100. They came with a great monitor too. :)
    I didn't see an owners manual link on ebay. If you can take a pic of the instructions maybe we can help you through it. I do understand how poorly some of those instructions can be.
  • I have no idea. I've used just a voltmeter for years. Close enough.
    At least the price was right.
Having RV issues? Connect with others who have been in your shoes.24,360 PostsLatest Activity: Feb 13, 2026
