rclassic99
Oct 14, 2013Explorer
help with water heater check valve
I have a 2005 coachmen Aurora 3480 with a 10 gal Atwood water heater. I get no water flow from the water heater to all hot water taps, the pump does not even start. When I put the bypass valve to the winterize position I now get water flow to the hot water taps. Not the hot water of course because I am by passing the water heater. The picture in my manual shows there are 2 bypass valves but I can only find one! In a separate place in the manual it shows there is only 1 bypass valve and only 1 check valve at hot water side. All of my other plumbing appears to be OK.
I am thinking it is a "check valve" problem. Any input or help would be greatly appreciated!!!
Thanks in advance
Vaughn
Thanks in advance
Vaughn
