otrfun's avatar
otrfun
Explorer II
Apr 05, 2014
High Efficiency 13.5k BTU a/c = Smaller Generator?
Here' some specs (BTU/Compressor Amps/Fan Amps/Inrush-LRA):
Dometic (standard unit) 13,500/12.4/2.5/63
Total amps: 14.9
Colman Mach (standard unit) 13,500/11.9/3.4/63
Total amps: 15.3
Dometic High Efficiency 13,500/8.6/2.5/50
Total amps: 11.1
Coleman Mach 3 PS 13,500/8.3/2.9/58.4
Total amps: 11.2
Once started these high efficiency units use about 3-4 amps less current than the standard units. The Dometic has a respectable 13 amp (63 to 50) reduction in inrush/LRA/startup current. A very good thing for smaller generators.
Did notice the Coleman Mach 3 PS had much less reduction in inrush/LRA/startup current vs. their standard unit. Wonder why? Quite a few small generators will never have the opportunity to see the reduced steady current demands because they'll never get the past the higher inrush/LRA/startup current.
Typically these high efficiency units can be purchased for $650-$750. Purchasing one of these might be a better investment vs. buying a larger generator--say, one EU2000 vs. two EU2000i's--$1000 vs. $2100 :)
  • NinerBikes wrote:
    Do you have a part number from Dometic for the high efficiency model? Are you sure it's a 13.5k or an 11.5k A/C unit?
    The part number for the Dometic high-efficiency a/c unit is 459530. As for whether I'm sure it's a 13.5k or not, well, I've seen it advertised as a 13.5k a/c, but ya never know . . . it could very well be a 11.5k in disguise :)
    Dometic brochure with specs
  • Brochure still recommends 2.5KW to start this 13.5 High Efficiency Unit. An Eu2000i puts out 1600, 2000kw tops.
  • otrfun wrote:
    smkettner wrote:
    Yes and unfortunately the fan starts before or the same time as the compressor.
    When will they figure out it is ok to run the compressor ten seconds before the fan kicks on.
    Or has this changed? I installed a new Dometic control box/digital thermostat a year ago and it starts the blower fan first by design.
    Can this Dometic digital thermostat be used on the garden-variety, Dometic 13,500 BTU, non-ducted, rooftop units? Got a part number? All the units I've seen, the fan runs constantly, 24/7. It would be awesome to have the fan turn off with the compressor.
    I've a standard 2 speed Dometic with the square box. There are 3 settings for the fan. AUtomatic, High, and Low. Automatic will run in the low fan setting it the thermostat setting is within 5* of the actual air temp inside, and if over 5*, it will start in the High setting.
    Since I mostly run my 13.5 on the generators, I almost always use the low setting, it especially seems to help during the first AC start up of the day, which draws unusually hard on the pair of Eu2000i's, unless nothing else is running at all on the travel trailer. By all means, use propane, not electricity to heat your water, and perhaps turn the AC off when running the microwave, if you are heating something up for lunch or dinner.
    True. But, on the other hand, Dometic recommends a 3.5kw for their standard 13.5k units. A number of folks have reported running their standard units with their 2.0kw Honda/Yamaha generators. Agreed, it's probably not recommended, but nonetheless they were successful. Given the 13.5k high-efficiency units use 25-30% less current (~11 vs. ~15 amps), I think it's a reasonable to assume a much higher percentage of folks could successfully power these units with their 2.0kw Honda/Yamaha generator.
Having RV issues? Connect with others who have been in your shoes.24,189 PostsLatest Activity: Jan 19, 2025
