Wo_ody's avatar
Wo_ody
12 years ago
High performance/heavy duty alternator battery charging
Sorry, Ben Franklin I'm not.
Late model Chevy DuraMax diesels have twin 125 amp alternators. If you want to create hp/hd alternator-to-TC camper battery charging then a few questions. As an example, lest say the TC has 4 each 12 volt by 200amp AGE in series.
How do you determine the max input amperage(less 15%) your system can handle?
What component in the electrics determine what amperage is sent to the TC battery series?
Can you send too many amps (too hot so to speak) back into the battery series?
Thanks
Woody
