CA_Traveler
Dec 18, 2014Explorer III
High Voltage DC Switch Source for Solar
I need a high voltage DC rated switch for 3 series connected solar panels. The panel ratings are Voc 37.45V , Isc 8.7A, so I’ve been looking for a DC switch rated at 125V and 10A. If there is a simple SPST switch for this application I haven’t found it. So far I’ve found:
1. Eaton DH221NGK, 2 pole rated 30A, 250V DC, for $110 plus $16 for 2 fuses. Total $126
2. Midnite Solar BabyBox for $32 plus $13 for a Din Rail Mount Breaker up to 125VDC. Total $45
10A and 20A breakers are available
3. Midnite Small Breaker Box MNEDC Quad for $58 which accepts MNEDC stud breakers for $20 up to 150VDC. Total $78
5A to 100A breakers are available
Both 2 and 3 accept 4 CBs up to 20A so they could be used with panels connected in parallel or series/parallel.
I have reservations about the Din Rail Mounting due to the increased connectors. Up to 4 breakers could be used for parallel panels. This box cannot disconnect both the positive and negative panel wires.
Two MNEDC breakers can be used to disconnect both of the panel wires for a cost of $98. Or any combination up to 4 breakers including one up to 100A for the battery wire disconnect. I favor the stud breakers due to isolation of each wire and reduced connectors.
Alternatives or suggestions?
