GordonThree's avatar
GordonThree
high voltage solar panels?
Has anyone experimented with high-voltage solar panels on their RV? I'm thinking along the lines of the 250-300+ watt panels that output 40-60 volts, versus the little 25-100 watt 12 volt panels typically used in RV systems?
Residential and commercial demand has really lowered the price of these big panels, there are many choices for under $1/watt compared to $2 to $3 per watt for the small panels.
I can see several downsides, like dangerous high-voltage DC current, and the need for an MPPT type charge controller versus the inexpensive linear / pwm units used on 12v panels.
But the flip side, two 250 watt panels versus five 100 watt panels - less glass to clean, less wiring to maintain and... fewer holes in the roof.
  • One regular poster on this forum (Jim - HiTech) even suggested that if the cost of an MPPT controller is too high for you right now, maybe use one or two of the higher voltage panels with a PWM controller to start with. If you need more solar power, you can just upgrade to MPPT controller and harvest more of the power generated by the panel(s).
    The economic reasoning is that a 250W 24V panel costs not too much more than a 140W 12V panel. So why not "pre-pay" for part of your next solar upgrade with a small incremental up-front cost. Plus the 24V panel will deliver more power early and late in the day when the sun is low.
    Plus the cost of MPPT controllers will likely drop in the future.
    Ed
  • Lots of people running high voltage panels with MPPT controllers. Not unusual at all. I not currently but my next RV setup will likely be that setup
Having RV issues? Connect with others who have been in your shoes.24,349 PostsLatest Activity: Jan 16, 2026
