dtappy3353's avatar
dtappy3353
His n Hers windows
The bedroom slide in our fiver only has 1 window (with screen/crank) at the head of the bed.
I would like to have a small slider/openable (sp) window on each side of slide for cross ventilation. We have ceiling vent and a crank window at opposite end of brm.
Has anyone ever had small windows installed in their brm slide? Are these small windows expensive and where do I find em?
Fiver open slide has 21" to work with.
Thanks for the feedback!
dt
  • A year after I bought our 2004 Rockwood new, I wanted to install a cargo door in the rear storage compartment. The factory had a small access door that was WAY too small for the storage area size. The next year, Rockwood realized this and fixed it with a larger door! I talked to the dealer to see if I could order the larger door from Rockwood. He checked and said yes, for $350 (for just the part)!!.
    I went on ebay and found a NEW door someone was selling. He had a batch of never-used doors from a door/window manufacturer that were mistakenly made slightly off-size. I paid $10 for the door (plus about $10 shipping), installed it, and it has worked perfectly since.
    Check ebay under RV parts and you may find a pair of windows far cheaper than getting custom ones made. You have a range of sizes that would work since there is no opening now. This gives you some flexibility in the window size.
    Steve
  • What I did was contact the manufacturer who made my 5th wheel and they sent me a schematic of how the framing in the wall were. It showed where the aluminum framing was with all the measurements.
  • I know of Peninsula Glass.
    Am in AZ till May. When I return to OR, I'll give them a call.
    Thank you very much for the help!!!
    dt
  • Trackrig wrote:
    If you're still in Oregon, you're in luck.
    In Vancouver, WA is Peninsula Glass, besides doing normal glass work, they build windows for MHs, boats, whatever you need. They build the frames, glass, screens and they install them. We started off going to them to build one screen and wound up with all of the windows and frames changed. Several of our windows we're fogged when we bought the MH. The screens they build are one piece, not something made up out of kits like you'd get at Lowes. They bend all of their own window and screen frames to whatever size and shape is needed. You'll have to call them to find out if they'll actually cut the hole in the side of you bedroom, but I think they will.
    They operate under three names for some reason.
    Peninsula Glass
    One Day Glass
    Motion Windows
    Ask for Jeff
    360.944.4446
    6005 NE 121st Ave.
    Vancouver, WA 98682
    [email protected]
    Bill
    Bill I agree with you. Peninsula Glass is right at the top (if not the top) when it comes to RV Glass.
    I'm having them build all my windows.
  • about 8 years ago, I purchased windows to match my wilderness rig. Somewhere on the frame was the manufacturer's name (Kinro, Inc).
    I contacted them, found a local dealer and was able to get two windows from them. They were small - 16" wide by 21 Inches tall.
    I had the issue that Drew pointed out. you need to see if where you want the window placed is crossing a support beam. If you do, you have to box it out like you do a stick house (post and beam construction), but that can make a mess out of your side wall(s).
    If you don't have anything in the wall where you want to place the window, they are compression fit (screws on the inside, butyl caulk and caulking on the outside).
    I'd use a stud finder to see if there are wires or studs in the walls where you're cutting....
  • DrewE's avatar
    DrewE
    Explorer III
    Do consider how the slide is framed internally prior to doing anything permanent in terms of adding windows. I would tend to guess that there isn't any framework in the way, but that's only a guess. (If there is, probably with enough work and reinforcement it could still be made to work satisfactorily, but it wouldn't be as simple as just cutting a hole and plopping a window in.)
    Other than that and potential clearance problems when sliding in and out, I can't think of any particular reason why a window couldn't be added.
  • If you're still in Oregon, you're in luck.
    Peninsula Glass
    One Day Glass
    Motion Windows
    Ask for Jeff
    360.944.4446
    6005 NE 121st Ave.
    Vancouver, WA 98682
    [email protected]
    Bill
