what would be the advantages and disadvantages of using either a 5th wheel hitch or a goose neck hitch for towing a 5th wheel??? Or is it just personal preference??? thanks
I would not adapt a 5th wheel over to a gooseneck. That extends the length of the 5'ers hitch and puts too much stress on it. Many people have done this though. The gooseneck has much much more articulation, but must be lined up perfect before dropping the trailer on it. I personally would want a factory gooseneck if I could choose. With campers you are almost always stuck with only a 5'er option.
What the advantages of a 5th wheel I can not tell you for I've only driven one once and it was a SEMI truck.. And many many years ago (like the 1970s) I know there must be some advantage but I do not know what it is. Will let otehrs cover that.
But there is also a "Disadvantage" in that you have that big 5th wheel gear sitting in the truck unless you remove it when not towing Takes up a whole lot of 'Floor Space' in the bed.
With a goosneck you have only the round ball and that may even retract so you have the full bed open for use when not towing and half of it when you are.
One caution however I've seen two gooseneck systems.. one is the Goose Box (I think it's by reese hitch but not sure) I have seen pictures and this is a good system to my eye.
The other is a king pin converter basically a long pipe that screws on over the king pin and has a ball hitch on the lower end.. . Now I've seen this one up close and bent all to hadies when the driver spiked the brakes (Actully it was the pin box that was bent) I would strongly recommend against it.
Has been debated for years here. Only real downsides mentioned is that it may void your warranty on a new trailer, it may be harder see the ball to hitch up, and the need for safety chains in many states since it is a ball type hitch. And hooking up the safety chains can be a little difficult for a shorter person. But most people who use them seem to really like them.
