SweetLou's avatar
SweetLou
Holding Tank Treatments and Your Advice on Lubricants
Might be in the wrong category, however I think it could also be a tech thing. What kind of cleaner or holding tank material do you use to help lubricate the valve seals? Are there DYI solutions used or just products that remove sludge? Are there multiple treatments such as holding tank solution then every so often put some other material in to keep seals working? I know about the ice method and traveling down the road, but this does not work if you stay put somewhere for awhile. Thoughts?
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
