SweetLou's avatar
SweetLou
Holding Tank Treatments and Your Advice on Lubricants
Might be in the wrong category, however I think it could also be a tech thing. What kind of cleaner or holding tank material do you use to help lubricate the valve seals? Are there DYI solutions used or just products that remove sludge? Are there multiple treatments such as holding tank solution then every so often put some other material in to keep seals working? I know about the ice method and traveling down the road, but this does not work if you stay put somewhere for awhile. Thoughts?
  • CRC 3045
    The CRC 3045 works well for a lot of jobs.
    I also use a good dry lube when you don't want the lubricant to attract dirt and grime.
    WD 40 works well for door hinges and other minor jobs as well as removing sticky residue if you are removing decals or labels.
    Bottom line is to use an appropriate lube for the job.
    For personal use, my preference is a good beer. I believe in supporting Ohio businesses and beers brewed by Great Lakes are at the top of my list. Dortmunder Gold is one you will most frequently find in the fridge along with many other friends. Variety is the spice of life!
    Wine is a good "lube" for the wife, but it has to be used carefully or she tends to fall asleep! Perhaps that isn't so bad?????
  • The knowledgeable RV people had me spending money on RV tank treatments, then I figured out they were not so knowledgeable. Tank smell inside the RV? The system is leaking and a plumbing smoke test will find the leak. NO chemicals for me. If you have money in your wallet Camping World and WalMart have a product to remove it.
    I added Zerk fittings to the holding tank valves and give them a bit of grease every now and then. I really do not care that petroleum may or may not be good for the seals, they are not going to last forever and I do not want to deal with stuck valves. I had my last RV 10 years full timing and the grease did not destroy the seals.
  • wopachop wrote:
    I've been leaning more towards silicone over the white lithium.
    Some rubbers dont like petroleum based lubes.
    The seals are not rubber. The seals are neoprene.
    Richard
Having RV issues? Connect with others who have been in your shoes.24,188 PostsLatest Activity: Jan 19, 2025
