Ron_Nielson
Jun 16, 2015Explorer
Holding Tank Wiring - Test wires
Most of the bottom of my Arctic Fox trailer is covered in cloroplast, a material somewhat like plastic corrugated cardboard, which holds the insulation in the bottom of the trailer. I have 4 wires exiting the bottom cloroplast about 4 inches long that are used to troubleshoot the tank monitoring system; Green, yellow, white and brown. These wires are not connected to anything below the coroplast - just terminated with crimp-on wiring terminal caps. Other end is connected to the tank monitoring system.
Wires from Trailer Bottom
I'm guessing that white is ground and the other 3 are for the 3 holding tanks, fresh, gray, black. How are these wires used for testing? Looking for voltage? Resistance? Something else?
