3_tons
Aug 18, 2021Explorer III
Not much to go on here equipment or system wise, but I’ll venture a guess here (WAG…)…. I would consider the possibility that when the converter is under a high current load, excess heat developes and triggers a internal overload device, causing amps to gradually taper-off (as well as heat) followed be another reset - Per your note it seems this cycling may have stopped once the battery recovered a bit…Just a guess only…
3 tons
3 tons
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: May 13, 2026
