time2roll
Aug 19, 2021Nomad
1L243 wrote:What converter? Once you hit peak voltage on the battery (14.4 volts?) run the generator one additional hour and you are done.
My converter has four charging cycles as the charging on 75% battery level begins the converter could show 25+/- amps as the batteries become more charged it drops to 15a to 8amps and by the time ths batteries are at 90% to 3 amps or less. Which make charging on the generator for only 3 amps a waste of gas.
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: May 13, 2026
