1L243
Sep 10, 2021Explorer II
I lowered the batteries to 73%. Then I let them rest for an hour and plugged into 110. And the cycling returned. I let it sit for 3 hours just in case there was a heat issue and still cycling.
I tested the battery voltage at the batteries at the same time the battery monitor shows cycling between 44 to .02 amps and the batteries go up and down a few 10ths of a volt at the same time as the cycling?? Clue??
I think my only choice at this point is to replace the Converter with a new one.
Should I go with a direct WFCO 8955 replacement or should I go with a after market?
Having RV issues? Connect with others who have been in your shoes.24,398 PostsLatest Activity: Jul 02, 2026
