bigfootford
Sep 11, 2021Nomad III
1L243 wrote:
Checked at power distribution panel and the voltage is going up and down a few 10ths of a volt as the converter cycles up and down. Plus the fan goes on and off as the cycle starts at high amps and then goes off as it gets to low amps. Over and over and over
I see Go Power makes a converter smart charger that will fit in the same place as the WFCO charger.
Any reocomendations?
Well that pretty much confirms the issue.... Bad converter.
Many of us recommend the Progressive Dynamics series of converters.
If you have questions you can call them. Randy is the owner and he knows about installing and recommendations.
https://www.bestconverter.com/Progressive-Dynamics-Converters_c_81.html
Jim
Having RV issues? Connect with others who have been in your shoes.24,398 PostsLatest Activity: Jul 02, 2026
