B92F's avatar
B92F
Honda 2200i or Honda 2200i Companion?
We are looking at buying a Honda generator and are having a discussion as to which one to get. At the moment getting both to run parallel is out of our budget.
I am assuming that either of these two can be run as a stand alone, and if that is so then is there any advantage to Honda Companion over the other? We're willing to pay the extra for the Companion if it's the better one for RV use.
  • The companion has 1 "normal" 120v 20A outlet and 1 120v 30A twistlock outlet. You obviously can't pull 30 amps from it without having 2 generators in parallel. The "regular" Honda doesn't have the twistlock; instead it has a duplex 120v 20A outlet.
    Either will work if you don't need to plug in more than 1 thing.
Having RV issues? Connect with others who have been in your shoes.24,338 PostsLatest Activity: Nov 28, 2025
