langbone's avatar
langbone
Honda EU 2000 fuel shut off not working
I installed a separate engine cut off switch on my two EU2000's. One works fine as it should and runs out of gas in about 2 minutes. The other one will not run out of fuel and die. The kill switch works fine. Could there be a wire from the Honda's switch that has become disconnected or any thing else I'm not aware of. Any suggestions?
  • I installed a switch so I could turn off the fuel switch and allow the engine to run until it ran the carb dry.Then hit the installed switch and kill the engine.
  • First, why did you install a switch? Supposedly the big ON switch is a fuel cutoff when turned completely OFF.
Having RV issues? Connect with others who have been in your shoes.24,201 PostsLatest Activity: Feb 19, 2025
