dryfly's avatar
dryfly
Honda EU2000i carburetor rebuild kit
I'm going to be making a trip to Yellowstone in the near future so I will need to be replacing the main jet in my EU2000i to one that will function in high altitude.
This will provide me with the opportunity to do a carb overhaul, even though my generator has less than 100 hours on it. Like most small engines, I assumed I could find a rebuild kit for the carb but so far no luck. Parts are available, but no complete kit.
Assuming all existing parts are in good shape, what needs to be replaced? One video I watched stated the large O ring type gasket between the float chamber and carb body, as well as the float valve seat need to be replaced anytime an overhaul is done. Is this usually true?
I'm seeing complete 3rd party carburetors on Amazon for $35 so maybe rebuild kits are obsolete. One of these with the high altitude jet, and the original carb with the standard jet would sure make altitude changing a lot easier.
  • I would swap on that $35 carb with the jet ready to go. Carbs are easy until they aren't. Then they are a PITN.
  • Admin wrote:
    Even if he replaces the carb, he still has to put in new jet(s) for the altitude, still may have to change out the seals.
    Unknown how long the new one has been sitting on the shelf.
    Admin
    New unused carbs sitting on a shelf should not have gaskets and seals going bad.
    Small engine carbs are dirt simple, unless you rip or tear the gasket, it will be reusable. There is only one "paper" gasket in the gasket kit that might cause an issue. However, in a pinch a new one can easily be constructed from lightweight cardboard from even a cereal box.
    Even the "O" ring for the carb bowl could be replaced by a cardboard gasket made from a cereal box in a pinch..
    This isn't like your needing to replace a head gasket, you just needing a way to create enough seal under a light vacuum so you get the correct air/fuel mix.. and for the bowl, just enough seal to not leak fuel..
    Used to reuse Holley fuel bowl gaskets many, many times when changing jets on the metering plate and not to mention the little "O" rings that went on the fuel tube between front bowl and rear bowl on four barrel carbs..
    As long as it isn't ripped or mutilated it can often be reused.
    I just don't think OP is going to really want to swap carbs in this case, it most likely will be easier to drop the fuel bowl and change the jet when needed.
  • Even if he replaces the carb, he still has to put in new jet(s) for the altitude, still may have to change out the seals.
    Admin
  • Generally, as long as you do not damage or tear the gaskets, you can usually reuse them multiple times before needing to replace.
    Looks like gasket kit is running $13 and new generic replacement carbs are starting at $37.
    HERE
    Might be a real toss on that one to outfit one carb with high altitude jet.. That carb looks like it is a bit of a challenge to replace with the stepper motor and hoses.. Not a simple change out..
    The jet should be accessible just by dropping the fuel bowl which depending on how much room you have may be easier to just swap jets than the entire carb..
    But if you really want to change carbs, I have had good success with lower priced aftermarket carbs on B&S and Tecumseh engines..
  • 2oldman wrote:
    We have a rebuild sticky post right here, but I don't know if it's worth anything as all the "free host" pictures are gone and apparently not being replaced. It's 24 pages.
    Not sure why you would need an overhaul at just 100 hours. Does it need it?
    Please see OP. I have to tear it down to replace jet anyway.
    I've seen sticky thread. Not looking for "how to do it". Looking for parts info, if needed.
  • We have a rebuild sticky post right here, but I don't know if it's worth anything as all the "free host" pictures are gone and apparently not being replaced. It's 24 pages.
Having RV issues? Connect with others who have been in your shoes.24,240 PostsLatest Activity: Apr 26, 2025
