Palominio89's avatar
Palominio89
Honda EU2000i Companion ?
I am new to camping. After my research we found we wanted to go with the two Honda Generators. We are just going to buy one for now, then add the other if even needed. my question is should i get the EU2000I Companion or the regular one first? My AC unit is 5000btu.
  • Ron3rd's avatar
    Ron3rd
    Explorer III
    Clarify something on the Companion; will the 30a RV plug plug in directly, or do you still need an adapter for the 30a RV plug?
    I already did ... the Companion EU2000i has a 30 amp twist lock receptacle so you need an adapter such as I linked to earlier so you can plug the trailer's main service cable 30 amp plug into it.
  • Ron3rd's avatar
    Ron3rd
    Explorer III
    That's what I thought I read a while back, so I guess my point is what is the advantage of the Companion, ie, how do you justify the higher cost?
  • Ron3rd wrote:
    ... so I guess my point is what is the advantage of the Companion, ie, how do you justify the higher cost?
    I've got but one EU2000i, don't plan to ever own two, but if I ever did I personally would not buy the Companion when dual standard models will work just as well. Heck, I'd never pay extra for a camo version either but apparently some do ... go figure! :h
  • You have 26.6 amps available from the Companion outlet vs. 20 amps from a regular receptacle on the standard model.
    Of course you would need the second generator to develop 26.6 amps.
  • I have a Companion. Love it. Runs our 9.2 A/C without a problem (turn A/C off to run microwave). I use a dog-bone extension to go from the 30A twist lock to the camper's 30A male plug. I feel it's a little more heavy duty than the puck plug converters, plus it offers a bit of flexible strain relief.
    An early heads-up: Virginia has a tax holiday May 25th-31st for Hurricane Preparedness. Generators, under $1,000, are included in the eligible items. Chain saws (under $350), duct tape, bungee cords, tarps, batteries, all kinds of stuff are Virginia tax exempt for that week.
    CLICKY
    http://www.vaemergency.gov/readyvirginia/stay-informed/hurricanes/sales-tax-holiday
