wa8yxm
Jul 05, 2013Explorer III
DO fill the main tank then hook up the extended run, As the Honda PUMPS (yes PUMPS) gasoline out of the main tank a vacuum will be created which SUCKS fuel out of the extended tank.. EVEN if the extended tank is lower than the main tank.
True story, EU-2000i without e-run tank.. Started, ran a few minutes, starved for fuel and died.. Several times.. Turns out they forget to open the vent valve in the cap.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 29, 2026
