SCVJeff
Jan 02, 2014Explorer
You need to fix the leak and you'll be fine. You also dont need to elevate the aux tank if the system is properly sealed. Mine is flat on the ground, and if you think about it in marine service, that tank is often 2' below the motor
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
