rjf7g
Jan 03, 2014Explorer
SCVJeff wrote:nevadanick wrote:It's not. He has the Aux tank elevated
I am suprised it will suck fuel with it leaking. If everything is right you dont need the aux tank above the Honda.
I am a "she" and I have tried it with the tank elevated and with the tank on the ground. The picture is from my old setup that worked like a champ as it was pictured before I replaced the fuel line and eliminated the primer bulb. Now, when the tank is elevated, gas leaks from the hole I drilled into the Honda gas cap and when it is on the ground it doesn't seem to pull any gas. I tried putting the tank on 4x4s and that didn't work either.
So, I have sealed around the fuel line better with silicon and will work on it some more when I go back to my camper later this month. It's going to be WAY COLD this weekend, so I am staying home!
Thanks for all of the help and explanations about how it *should work*.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
