Prowler_Doug
Jan 03, 2014Explorer
rjf7g wrote:
Yes - it is leaking out around the cap. So, there is an air leak, but in my previous setup there was as well. I have tried changing the height of the marine tank and it overfills when I place it above and fails to pull any when I don't. So, I should be airtight at the Honda cap and simply vent the marine tank?
Thanks for help with this. I thought with the primer bulb that I would be able to get the gas pull started and then maybe the Honda fuel pump would take over...
This setup *used to* work perfectly!
Doesn't need to be elevated.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
