PaulJ2
Sep 27, 2013Explorer
So wrote:PaulJ2 wrote:
I still think you will find that the ICM ignition module is the problem. Diagram shows that there are two ways to kill the spark--by the ignition key switch grounding the spark, or the yellow wire from the low oil device grounding the spark. Both cause the coil black wire to go to O ohms stopping the engine.
The diagram also shows that if you disconnect the ignition coil's primary side black wire (at the coil), it will completely isolate the ignition coil from the rest of the circuit... including the ICM.
If the ignition coil is fully functioning, properly installed and the spark plug is equally functional, HV spark will be produced whenever the ignition coil's black wire is disconnected... and the flywheel is spun fast enough.
This does NOT imply that the engine will run, it does however, validate the functionality of the ignition system.
So- Yes I thought of that too. Maybe the only reason for the so called "ignition control unit" is to operate a warning indicator lamp.
Having RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Sep 13, 2026
