otrfun
Apr 14, 2023Explorer II
jodeb720 wrote:Is this *Supco* Soft Start you're referring to an aluminum-cased electrolyitc capacitor? If it is, they're only capable of reducing inrush current a few amps---very ineffective. A Micro Air Easy Start, a plastic box with circuitry inside, can reduce inrush current (LRA) as much as 25-40 amps. This is a massive, huge difference in capability.
I have a supco soft start on the AC unit already - which is how, I can get the 2000 to get the AC going; However, if i'm altitude or it's really hot, after 20 minutes it overloads the 2000's surge capacity.
Hence i'm looking at a bigger unit . . .
Soft starts aside, to give you a clearer picture of your power needs, I'd suggest looking up the continuous current rating for your a/c unit. Or, better yet, use an AC clamp-on ammeter to verify the continuous current while it's operating.
A BTU rating only gives a very general idea of an a/c unit's power needs. Some of the more efficient 15k BTU a/c units can draw less continuous current than some 13.5k BTU a/c's. If the continuous current rating/reading is less than 13a, and a MAES is used/installed, most 2000w inverter generators (in good running condition) should power it. If it's less than 15a, the newer 2200w Honda generator should power it.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 29, 2026
