- ktmrfsExplorer II
SoundGuy wrote:
burningman wrote:
The EU2000 can usually handle an A/C running, just not the compressor start-up.
Sure it can - Micro-Air Easy Start Soft Starter Kit ... and the new EU2200i would handle this task even better. :B
well, absolutely, sort of. In my case, yes with the micro air it easily will handle startup under every condition I have experienced.
And the startup is smooth, no grunt, no fuss even at 4500Ft on a very hot day. However, you still have the issue of long term overload. Not an issue at lower temps and lower altitudes.
But I found out that at 4500ft and 90F, after about 10 minutes the poor honda 2000 would trip out on overload. Now looking at temp, barometric pressure and humidity, my density altitude was about 6000ft.
so, it was drag out the other honda and parallel them.
But since it would run for 10-15 minutes before overload, I'll bet the 2200VA unit would probably get me from "almost adequate" to "barely adequate". and would make the slick ticket. - SoundGuyExplorer
Sure it can - Micro-Air Easy Start Soft Starter Kit ... and the new EU2200i would handle this task even better. :B - ktmrfsExplorer II
SidecarFlip wrote:
burningman wrote:
I have tried paralleling combos of EU1000, EU2000 and EU3000 Hondas and in actual practice they all play well together. And no, the smaller one doesn’t go into overload as soon as a big load is turned on. I can’t imagine any problem running a 2000 with a 2200.
I’m pretty sure you can even parallel an EU with a pure sine wave inverter but I haven’t (yet) tried it. As many - but maybe not all - of you know, when paralleling these things the 120VAC outputs of each are simply connected directly together. There’s no other magic synching signal, the parallel operation ports are only connected directly to the regular 120VAC outlets. An EU just synchs up to another 120VAC source, it doesn’t necessarily have to originate from another Honda. 60hz 120VAC is 60hz 120VAC.
I might try that out because that might be a good way to run an A/C off a single EU2000.
I’d like to try running a battery charger off the Honda to top off a pair of deep-cycles, which are paralleled with the Honda to provide the extra power to start the A/C. The EU2000 can usually handle an A/C running, just not the compressor start-up.
In actuality, it don't even matter what brands they are. All the parallel kit 'sees' is the output so if they are both PSW units, should make no difference at all.
Well, not as simple as it seems. there are 3 things that must be controlled when paralleling, frequency, phase and amplitude.
Frequency and amplitude between two inverter generators is likely to be pretty close under no load conditions. fractions of a hertz and maybe a few volts amplitude. something that can be synced together pretty quick and easy with good control circuitry.
Phase is another story, it is completely arbitrary and uncontrolled and will be between 0 degrees and +/- 180 degrees apart.
That is the big one that needs to be brought into sync very quickly, and very soon frequency and amplitude.
The easy case is with one running generator paralleled to another non running generator. The first running generator can easily be designed to control the second generator to sync the phase frequency and amplitude as it fires up.
And that's the normal (at least for me) starting procedure.
The second case is paralleling two running generators. This is a harder thing to do.
If both generators are running when they are paralled they do have to have a way to sync and phase the output voltage and frequency and amplitude and stay on the same exact frequency in phase and same amplitude and do it pretty quick, within a few cycles.
I've never tried unhooking the parallel cable between two hondas, fired them up then connected the parallel cable to see what happens. A well designed control circuit likely could accomidate this case as well. in the case of inverter generators that the inverter control circuit for generating the PSW output is designed to bring two units into sync for phase, frequency and amplitude with individual startup.
A stable control circuit needs to be able to have enough range to swing all three parameters into control limits anyway, so designing too be paralled after startup wouldn't be that hard to do at all.
If the frequency is off, or phasing is off and it stays that way it's an easy way to impending disaster.
Hooking one in parallel to a PSW inverter? question is will the generator lock to the inverter or try to get it to move? the inverter probably is not expecting to be paralleled with something else and likely tries to run off it's own internal frequency reference. and it only takes fractions of a hertz variation to yield problems. likewise with phase and amplitude.
worth a try, but expecting it to be universally successful is not something I would expect. - SidecarFlipExplorer III
In actuality, it don't even matter what brands they are. All the parallel kit 'sees' is the output so if they are both PSW units, should make no difference at all. - burningmanExplorer III have tried paralleling combos of EU1000, EU2000 and EU3000 Hondas and in actual practice they all play well together. And no, the smaller one doesn’t go into overload as soon as a big load is turned on. I can’t imagine any problem running a 2000 with a 2200.
I’d like to try running a battery charger off the Honda to top off a pair of deep-cycles, which are paralleled with the Honda to provide the extra power to start the A/C. The EU2000 can usually handle an A/C running, just not the compressor start-up. - ktmrfsExplorer II
Bobbo wrote:
I wonder if a new EU2200i can be paralleled with the old EU2000i.
the data sheet I saw said YES. the have two models, just like the existing 2000 and either can be paralled with it'x complement, 2000 0r 2200 - BobboExplorer IIII wonder if a new EU2200i can be paralleled with the old EU2000i.
- wnjjExplorer II.
MEXICOWANDERER wrote:
The best gets better but predictably there will always be those who whine about price. Regardless, Honda will no doubt sell every new EU2200i produced to a willing market looking for a quality genset that maintained properly will reliably serve it's purpose for thousands of hours.
Very similar to new customers of mine. "Then there is WOOT from Amazon and their 50% off sale. Twenty Four Dollars for a seven dollar duplex electrical receptacle"
Value is value. Differeing strokes and all that.
STYLE. Oh yeah -- look at DYSON vacuum cleaners. Appliances right out of the movie "Alien"
I thank my lucky stars I can choose among brands to satisfy my quirky nature.
Don't use that Dyson for immoral purposes. I hear they have a fan blade in the nozzle...........:B - MEXICOWANDERERExplorerThe best gets better but predictably there will always be those who whine about price. Regardless, Honda will no doubt sell every new EU2200i produced to a willing market looking for a quality genset that maintained properly will reliably serve it's purpose for thousands of hours.
Having RV issues? Connect with others who have been in your shoes.24,288 PostsLatest Activity: Jan 09, 2022
