RRTom's avatar
RRTom
Hooking grill to onboard propane
We purchased this grill at Camping World. We were told the only way we could use it was with the small 5 LB propane canisters. That we could not use any adapters to connect to our onboard propane tank connection. While at the dealers yesterday, I was looking at the adapters and saw one that looked like it should work. MEC brand. Of course I didn't take a photo of it and now I can't find it on line. The tech at the dealer said there was no reason I couldn't connect to the onboard tank. Any thoughts, suggestions would be appreciated.
https://www.campingworld.com/smoke-hollow-vector-series-smoking-tabletop-3-burner-gas-grill-86915.html?cgid=grills#start=4&cgid=outside-rv%2Fgrills-picnic%2Fgrills%2Fgas-grills
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    There are two (really 3) adapters.. Now I do not think Marshall Brass still makes 'em (At least last time I looked they were not in the MB online catalog) but they were called the "Extend-a-Flow" which came in two models one stright through and the other right angle, and the Extend-a-stay, All of these have a Round "Quick Connect" fitting, like you find on the top of a throw-away Propane bottle So any propane grill designed to use throw aways work with them. With an adapter many designed to work with luggable's like the 5 to 25 pounders will as well (Though the really big ones may not)
    THe extend-a-stay is designed for Motor Homes like I have.. with this there is a 2nd hose included where you can hook up a luggable tank to feed the RV.. Have done that on occasion. Very handy .
  • Roger10378 wrote:
    You need to tell us if the regulator is at the tank end of the hose or if it is part of the grill. If it is at the tank end of the hose it is easy to convert to a quick connect and run off the MH. If the regulator is part of the grill it gets complicated.
    The regulator is at the tank end of the hose.
  • You need to tell us if the regulator is at the tank end of the hose or if it is part of the grill. If it is at the tank end of the hose it is easy to convert to a quick connect and run off the MH. If the regulator is part of the grill it gets complicated.
  • I use a splitter on my 20lbs trailer tank to run a 20’ hose to my bbq. The splitter has the same screw type fitting as the bbq and allows me to run the line before the trailers’ regulator.
    The other way is if your trailer has a quick connect port for a gas line. Remove the bbq regulator and add an adapter to use a hose into the quick connect port. A search on here or google will show how and what you need.
  • You can only use one regulator with an appliance. If you connect to the RV system anywhere after the RV's regulator, you would run directly to the grill with it's regulator removed. If you connect directly to a propane bottle, then a regulator is required.
  • 2oldman wrote:
    "Includes a hose for connection to a 20-lb. propane tank (sold separately)."
    thanks. I don't remember any extra hose with the grill. But now I know that is doable. Now I need to find out if I can connect to the Motor Home's propane.
  • "Includes a hose for connection to a 20-lb. propane tank (sold separately)."
Having RV issues? Connect with others who have been in your shoes.24,315 PostsLatest Activity: Sep 12, 2025
