I have 1 drum brake that stops hotter than the other 3. I replaced all seals because of grease leakage. Hot brake was greaseier. I cleaned better than others. Do I need to clean other 3 better? Do I n...
I had 1 about 25-30 degrees hotter than others. With a flashlight and tiny tiny mirror I rotated the star wheel adjustment thing 3 ridges backwards and fixed. But I suppose every setup is different. Long uphill offramp not using brakes to stop then take temps to see if brake shoe is dragging or applying more brake pressure than others is guessing game at first.
