I have 1 drum brake that stops hotter than the other 3. I replaced all seals because of grease leakage. Hot brake was greaseier. I cleaned better than others. Do I need to clean other 3 better? Do I n...
Thank you for your help. I think I will back off adjuster on hot brake to start with. I have a temperature check gun, I will compare to other brakes. If it's still a problem then will buy a backing plate brake kit for all 4. Thanks
